2000 Chevy Blazer isnt engaging to 4wd
Old Dec 4, 2016 | 03:04 PM
jroberts87's Avatar
jroberts87 is on a distinguished road
Default 2000 Chevy Blazer isnt engaging to 4wd
Hello, First time posting. I purchased a 2000 Chevy Blazer 4.3 4wd Automatic.
The issue im having is it isnt actually engaging to 4wd. The lights go normally from 2hi to 4hi, I hear the clicking from under the dash and im hearing a clicking underneath the vehicle.
Even pulled off the battery and tray to see for vacuum leaks, and my actuator is currently engaged, But when I click from 4hi to 2hi it doesnt disengage. But im not in 4hi?
My idea is maybe the cable is stuck or the Transfer case switch is seized?
Any help would greatly be appreciated.
Old Dec 5, 2016 | 08:29 AM
LesMyer's Avatar
3 button or 4 button controls? But first please read appropriate articles here and ask any questions you may have. If the 4WD light is staying on steady, then the front axle is probably not locking. Easy to check.
https://blazerforum.com/forum/tech-a...e-first-30093/
Old Dec 5, 2016 | 08:42 AM
jroberts87's Avatar
The 4wd switch works and its 3 button
Old Dec 5, 2016 | 09:36 AM
LesMyer's Avatar
OK - with it in 4WD and engine running (trans in park), jack up the passenger side front wheel (only) off the ground. Can you rotate the wheel by hand? If so, does the front driveshaft turn when you rotate the wheel?
Old Dec 5, 2016 | 03:39 PM
jroberts87's Avatar
So far I can turn the axle by hand. But then again it was turned off. I replaced the 4wd switch and the transfer case motor switch cause it ceased. But still nothing.
Old Dec 5, 2016 | 09:02 PM
LesMyer's Avatar
this isn't what we discussed before
Old Dec 6, 2016 | 02:27 PM
jroberts87's Avatar
Sorry. with the weather the past couple days I just did what I could. But once it quits pouring out I'll check everything you said. Just getting discouraged Cause i thought replacing the seized transfer case motor switch would fix it. I just dont understand if theres vacuum going to the actuator. Which isnt it already in 4hi.
seriosbrad
Nov 7, 2015 09:08 PM
16sweetangel
Engine & Internal
Sep 22, 2013 03:13 PM
bmx4life218
Aug 3, 2010 01:32 AM
Dbrown843
Dec 20, 2009 08:01 PM
YOURCONNEXX
Oct 21, 2009 07:10 PM
