2000Blazer driver seat dosen't lean back !??? HELP !!!
Hi!
i just bought a blazer2000 and my first deception is that the driver seat dosen't lean back (like if i would like sleep in driver seat) is it broken or is it normal??? I've been searching the web for hours and found nothing... Help me please ! Mats |
gonna ask a stupid question but the handle is there right? i do no that a big problem on these trucks is the handles breaking both of mine are broken
first question is: is an electric seat or manual? If it's electric; on the side of the seat are two controls, forward one parallel with seat bottom moves entire seat up & down, forward & back, tilts it back and forth. Rear one parallel with seat back lays the seat back like you desire. If you have 'em and they don't work then it's an electrical problem. If you don't have the electric seat then yeah, the handle is broke off. Mine has electric driver and manual passenger seat
mmmm
Thx for the fast answer!!
its a non-electric, the handle dosen't seem to be broken, the seat goes down/forward perfectly. BUT the handle, instead of being on the low side of the seat is located on the side, on the "back" part of the seat .......l .......l .......l (driver seat, dots=necesary for ) ---> l____ thx again!! |
Originally Posted by YorkQC
(Post 223817)
its a non-electric, the handle dosen't seem to be broken, the seat goes down/forward perfectly. BUT the handle, instead of being on the low side of the seat is located on the side, on the "back" part of the seat l l l ---> l____ thx again!! Is your truck 2 door? The way you describe it, it sounds like you are talking about the handle on the back of the seat that is used to push it forward to allow passengers to get in the back. The actual back part (where you rest your back while driving) of the seat is controlled by a handle located on the door side of the seat.. Mine just so happens to be broken as well. |
ya, there should be two handles on the seat, a lower horizontal mounted one, and a vertical mounted one located on the back-rest portion of the seat... The vertical one tilts the seat forward in order to allow for passenger access... the horizontal one tilts the back-rest forward and backward... If you havn't found it it's probably because the handle is broken... I've actually seen the rod that the handle twists break, depending on where it broke you could be SOL... I'd suggest posting some pics.
ROFL. Both of mine are broken off too. Right where the handle ends and the pot-metal shaft (heh) that runs into the seat starts.
If you are planning on sleeping in your Blazer, just pop the hatch and lay down the rear seats. PooF! Now you have a bed that fits you, you and a pal, or you +2 if you're a freak like that (though not comfortably :p) A lot less homeless kid looking that way, now you look like you're camping. *BTW g/l finding a junkyard seat that ISN'T broken. Unless you can get a power seat OR swipe something elses seat (i.e. a Yukon) You're stuck. Welcome to being a Blazer owner :D |
mine seat handle broke the other day too:(...i havent touched since i bought the blazer 2 years ago and one day i open the door and the handle is just siiting on the floor.
Originally Posted by okvortec
(Post 223820)
yes its 2 doors !! the handle can make de seat goes down (front side) but not backward like i would sleep, is it broken anyway??? And i haven't seen anything looks like i have a HORIZONTAL ONE missing..... |
Reserved for pics. Give me a few minutes to take some and upload em.
| All times are GMT -5. The time now is 05:53 PM. |
