-   -   2001 blazer abs tranny problem, weird stuff! (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/2001-blazer-abs-tranny-problem-weird-stuff-34512/)
dharwood 09-07-2009 10:30 PM
2001 blazer 4.3 auto 4wd --------- abs light came on and off for couple of miles. I parked overnight now abs light stays on , while driving brake light on dash comes on and off intermitently, when brake light comes on transmission downshifts to 1st gear when brake light goes off it shifts up where it should be, abs light stays on all the time. any help would be greatly appreciated thankyou
shade tree 09-08-2009 06:44 AM
I have the same problem with the (ABS) and Brake warning lights coming on intermittently,but the transmission does not shift when this happens. The advice I got here is that it is probably a bad wheel bearing leaking grease onto the (ABS) sensor.
dharwood 09-09-2009 09:00 PM
tried new wheel sensor
speedo stopped working. tried plugging in new wheel hub on each side ,abs light still on. going to check tranny wires to speed sensor maybe its a connection problem its worth a shot
mark1025 07-31-2016 08:40 AM
I have just had this problem start. Tranny not shifting properly and the ABS light comes on.
I see this is an old thread but figured WTF. post on it anyway. I was thinking the speed sensor also. Goin out to look into it in a few minutes
twpogue 07-31-2016 11:43 PM
Speed sensor is the first thing I'd look at.
mark1025 08-02-2016 06:10 PM
weird fix
My AC was also messing up. it would cut in and out. The plug on top of the compressor was loose. I bent the prongs on the compressor toward the radiator. Plug was now tight. I figured the two problems were not connected.
Drove 150 miles no problems. No ABS light and transmission is shifting fine :icon_shrug: Might be because when the compressor turns on it kicks up the idle?
slimsummers 08-04-2016 10:07 PM
Sounds more like a bad ground issue, the PCM controlling the trans shifting shouldn't care much about the ABS system malfunctioning. Was the speedo dropping out when the trans downshifted? That and the PCM shifting commands depend on the VSS in the transfer case. If it wasn't dropping out, the speed signal was still good during the problem.
AC only kicks up the idle at idle, not when you are driving down the road!
Bad grounds can cause all sorts of weird computer issues as the power from a heavy draw item can try to find a path to ground through the grounds on the computers.
First thing I would do is hit AutoZone and get your codes read, if any. That might give a clue to the source of the issue.
mark1025 08-07-2016 06:37 AM
Hi about 400 miles since fixing the plug on the ac. Still working fine.
The speedo was reading wrong or not at all when i had the shifting problem. I have a code reader. Po141 sensor 1 bank 1 is the only code. Im not looking forward to changing it. I dont think its going to come out in one piece :(
For now the blazer is running great:)
thanks
