2001 Blazer - Differential Lock Not Engaging/Disengaging
Old Feb 16, 2014 | 11:06 AM
tony991's Avatar
tony991 is on a distinguished road
Default 2001 Blazer - Differential Lock Not Engaging/Disengaging
I have a 2001 Blazer, One day I was coming off the highway and there was a "siren" noise coming from the front end of the truck. I determined it to be the differential lock. In 2wd it makes the "siren" sound while driving in four wheel drive it does not. But when I use 4wd to climb my driveway with snow and ice the front differential engages and disengages repeatedly and it doesn't fully lock in 4wd. I removed the battery tray and had someone switch it back and fourth from 2wd to 4wd. It pulled in and has the same constant vacuum. I don't think there's a fault with the lock actuator. What do you guys think the problem is? Any help with be appreciated! Thanks!!
Old Feb 16, 2014 | 06:59 PM
The problem is low, or inconsistent vacuum to the axle actuator under the battery tray. 3 or 4 button switch on the dash for 4WD?
Old Feb 17, 2014 | 06:27 AM
tony991's Avatar
I have the 3 button switch. 2wd, 4high, 4low
Old Feb 17, 2014 | 08:01 AM
There is a tech article with this exact scenario explained in the title! Check it out!
seriosbrad
Nov 7, 2015 09:08 PM
amccain
Nov 25, 2010 06:36 PM
Quicksilver
Jan 7, 2009 09:12 AM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
juliensales
Mar 29, 2005 12:16 PM
