2001 Blazer timing chain cover gasket
Old Jan 26, 2013 | 10:10 PM
Tan2001BlazerLS's Avatar
Tan2001BlazerLS is on a distinguished road
Default 2001 Blazer timing chain cover gasket
The timing chain cover gasket is leaking oil and the place i took it to wanted $1500 in labor. I can't afford that, so what are the things i need to do to replace this. And, what do i need to do this replacement.
Old Jan 27, 2013 | 07:06 PM
LannyL81's Avatar
Is this a 2WD or 4WD?
If 4WD there is alot involved in getting the front cover off; either rhe engine has to be lifted or the front differential lowered in order to get the oil pan off. The oil pan must come off before the front cover can come off as the gasket goes across the interface.
So the $1500 price tag does have some rationale behind it.
I need to do this repair as well on my '02...common problem with the plastic front covers.
And also part of the repair requires the correct computer tool to tell the Blazer engine computer to do a "crank position sensor relearn"....since you have to move the sensor...its in the front cover.
Good luck.
Old Jan 29, 2013 | 12:07 AM
step66's Avatar
X2 to Lanny, but doesn't the cover itself need to be replaced as well? It seems I read that somewhere,probably here...
Old Jan 29, 2013 | 12:42 PM
LannyL81's Avatar
Yep...the plastic timing cover will need to be replaced along with the gaskets (oil pan and timing cover, crankshaft sensor O ring).
Does X2 mean 2wd?
Old Jan 29, 2013 | 07:58 PM
Lanny, X2 means he agrees with you
Timing cover gasket usually leaks if the cover is removed and reinstalled, (they must be replaced).
Old Jan 29, 2013 | 09:31 PM
rockp2's Avatar
Just out of curiosity, why does the timing cover need to be replaced? I know it does, it's in the TSM and stamped right on cover itself. I'm actually ordering mine from GMpartsdirect tonight...but I've always wondered if it is good shape when it is removed, why does it need to be replaced?
Old Jan 29, 2013 | 09:46 PM
Because if you don't, it leaks
It's late, can't remember for sure, something about the plastic getting distorted or brittle being exposed to heat, (from the block).
Old Jan 30, 2013 | 10:37 AM
LannyL81's Avatar
[QUOTE=Captain Hook;564930]Lanny, X2 means he agrees with you
QUOTE]
Seems I need to get out more often.....LOL....
drblaze
18
Jun 22, 2011 01:58 PM
Bonedaddy
Jul 6, 2010 05:14 PM
gabenton
Mar 26, 2010 08:23 AM
CDJr
May 21, 2009 01:43 PM
black95blazer
Jan 30, 2008 05:01 PM
