-   -   2001 Jimmy - Vacuum Noise under hood? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/2001-jimmy-vacuum-noise-under-hood-70550/)
Meash May 8, 2012 10:42 AM
Hi folks,
I have a 2001 Jimmy, 150K fully stock 4.3 vortec. Occasionally I hear a humming vacuum like noise coming from under the hood. The only way to get rid of it is to turn off and restart the truck. This usually works 95% of the time. The noise may not come back for days or until the next stop, and start of the engine..
It does not sound like a belt whine or anything like that. More like a kettle whistling (but not as high pitch). All vacuum lines look good, but why would it stop and start if I shut down and restart the engine, say at a red light?
Any help would be greatly appreciated.....
Thanks in advance :-)
Easy48827 May 12, 2012 10:42 AM
I can't give a definite answer but my 96 Jimmy does the same thing on occasion. I describe my noise as a rushing wind sound which happens on start up on a cold engine and goes away when it is warmed up. I have always assumed it was the fan clutch engaging when is probably shouldn't. Just a guess.
Ogre762 May 14, 2012 04:07 PM
Not sure, you may have to see what part of the engine bay it's coming from. Possibly EGR or Charcoal canister venting?
chcknugget May 15, 2012 12:17 PM
Fuel lines??? I had my supply line replaced and ever since it makes a vacuum noise... When it warms up or the lights are on the noise quiets down for some reason.
