2001 S-10......ABS Light and ABS Fuse
Is there a way to kill the ABS Light without fixing the ABS system? Can I pull the fuse or relay? And where would the realy be? I know I need ABS work done on the right front wheel but I personally do not like ABS.
It will not cause your light to turn off if that is what you are after. Why not fix the issue? What is it doing?
| All times are GMT -5. The time now is 10:52 AM. |
