2002 Blazer Front Axle Actuator Location
Can someone please tell me where the "Front Axle Actuator" is located on a 2002 Blazer? Any photos available?
Originally Posted by Bono4783
(Post 617264)
Front Axle Actuator
Thats the Vacuum Actuator, I am looking for the Front Axle Actuator, it has an electrical plug in and two vacuum hose ports.
I believe you are referring to the Front Axle Actuator Solenoid Valve. Which I understand to be located on the firewall about in the center for an NV236 TC (four button). The Front Axle Actuator is located under the battery tray.
Did a quick search. This page has a pics of it's location about half way down the page. Front Drive Axle Vacuum Actuator Solenoid Valve?
Heres my problem
I have a 2002 S10 Blazer. It shift into 4wd fine but when I go to put it back into 2 wheel there is a delay, sometime several miles and the a loud bang like someone hit the bottom of the vehicle with a hammer. I have changed out the vacuum front axle actuator (under the battery) and I am in the process of changing the Front Axle Actuator Solenoid Valve. Am I replacing the right items and is there anything else that I need to look at?
Typically a difference in propeller shaft RPM is what causes the "bang" on disengagement. If one tire is worn more than the others, that could cause it. The circumference of all 4 tires/wheels must be identical. All 4 tires and wheels must be the same size, same manufacturer is better yet. All 4 must be inflated equally.
Another thing you might want to check. I had a similar loud bang. The five 15mm bolts holding the tube and the plastic cable actuator to the front diff had backed out slightly.
If anyone has ever been in there good chance of improper torque. Had a hell of a time finding it. |
2 Attachment(s)
(Post 617332)
EDIT: Just to note, I am not suggesting this is the reason for your "clunk". |
Thank you rock2p
I appreciate your reply. I went into my local auto parts store and thats what he sold me. I've looked all over the engine bay and couldn't come up with it. Thanks again for your help.
| All times are GMT -5. The time now is 07:15 PM. |
