2002 ZR2 lowbeam problem
Old Nov 5, 2023 | 06:23 PM
Ratamus's Avatar
Ratamus is on a distinguished road
Default 2002 ZR2 lowbeam problem
I noticed my headlights (low-beams) were not working on my drive home a few nights ago. On this model my DRL's are my low-beams and that isn't working either, high-beams and everything else seems to be working fine.
I've tried replacing the low-beam bulbs, swapped the DRL relay, tried another headlight switch I had. I think the light sensor is working fine since my dash was illuminated the night I noticed my headlights out.
I'm thinking the next step is to check the wiring and ground, anyone else have any suggestions?
Old Nov 5, 2023 | 07:16 PM
I've tried replacing the low-beam bulbs, swapped the DRL relay, tried another multifunction switch I had. I think the light sensor is working fine since my dash was illuminated the night I noticed my headlights out.
I'm going to assume your circuit is similar to my 99.
On mine, the DRLs use the filaments of the low-beam bulbs, but in series rather than in parallel when the used as low beams at night.
Could there be some other relays you could check? I don't have my diagrams with me, but my gut tells me there could be at least another relay involved.
Old Nov 7, 2023 | 10:35 AM
El_Beautor's Avatar
I had a similar issue with my 02 Sonoma a while ago, and came to the conclusion that it was a grounding issue. The challenge is that these trucks use a very complex circuit for the high/low/DRL systems that switches both the positive and ground wires depending on which light is requested. To further complicate things, there's a few different circuit possibilities depending on what year and model of truck you have.
On my truck, during diagnosis I actually realized that doing the quad beam mod (both high and low beams on when high beams are requested) would fix my problem, so I just did that mod instead of continuing to try and chase the ground issue. On my system that just involved grounding the yellow wire at the driver-side headlight.
Halfalive
Dec 18, 2022 01:48 AM
LordBlazer
Nov 2, 2021 11:00 AM
nightrider76
Dec 5, 2020 11:30 PM
Blazermoneypit
Jan 9, 2019 05:42 PM
TheJohnnyRaygun
Jan 17, 2012 04:13 PM
