2003 Blazer 4x4 issue.
Old Feb 1, 2026 | 05:04 PM
JohnRM22's Avatar
JohnRM22 is on a distinguished road
Originally Posted by LesMyer
I would start by checking for any helpful codes per https://blazerforum.com/forum/tech-a...gnostics-7683/
Any advice on what to use to short the two pins on the OBD2 connector? Would a bent pater clip work or would I need something more precise?
Old Feb 1, 2026 | 09:15 PM
LesMyer's Avatar
the paper clip will work fine
Old Feb 1, 2026 | 10:50 PM
JohnRM22's Avatar
Ok, I’ll give that a try in the morning. Hopefully with some kind of news.
Thank you!
Old Feb 2, 2026 | 09:42 AM
LesMyer's Avatar
If you are disconnecting battery to get to work, you cannot trust that a code 1 isn't from disconnecting battery and that all codes have been wiped out.
Better to just clear all codes (verify they are cleared) and get things to fail again/code to set before truly believing any codes (or lack of them). Reason is in attached document. Also, sometimes failures have to repeat a number of times before a TCCM code will be flagged.
Read especially encoder switch monitor test section. Aren't you only getting 2hi and 4lo when in failure? I think it's looking like encoder motor, but you should verify.
Good luck and best wishes for a successful repair! Sorry, I had to read on this a bit because mine is a 4-button and diagnostic methods are quite different.
Old Feb 2, 2026 | 11:35 AM
JohnRM22's Avatar
Actually, I’m getting a 2Hi to 4Hi problem. It will shift to 4Lo.
Old Feb 2, 2026 | 05:51 PM
LesMyer's Avatar
so per post #3, it will go into 4lo and 2hi when the problem occurs, but not 4hi. What I said reflects that.
aloha
Sep 17, 2024 12:16 AM
carlbirt
Nov 21, 2011 11:12 AM
JasinP
Dec 17, 2010 01:15 PM
benp#38
Oct 24, 2010 06:40 PM
TheJuicer
Feb 23, 2009 02:59 PM
