2004 4x4 4 door blazer problems
Hello, I am new here and new to car owning in general. I have a few questions that I hope can be answered here. I have a 2004 4 door 4x4 blazer i purchased almost a year ago and ive been fixing and replacing things to get it running again. I have been able to finally get it running and its been reliable so far. My question though is when I am driving I can tell that my feet are getting warm. My AC is not working currently so I do not have it on nor do I have it on the vent or on the hot side of the dial. I am wondering if there is a leak or if that is normal. I am also wondering what kind of upgrades I can get for my vehicle. Like I said I am new to vehicle owning as this is my first car. Another thing I have noticed is that my doors do not actually lock and my driver door is not aligned properly to the latch. What can I do there because I have tried looking up door replacements but have not been able to find any. I appreciate anyone who will be able to help!
As for vehicle upgrades, there's so many options, you need to decide if you want to Raise/lower/stock upgrade it lol. For the door alignment, I would look into the door hinges pins. And the locks, I would start with fuses, then check the door to see if everything is hooked up properly in the mechanism.
Door alignment is likely worn or broken hinge pin bushings.
Please explain the door lock situation more. The lock works with the key but not the electric lock switches in the doors? All doors? All switches? How about the remote? George |
Originally Posted by GeorgeLG
(Post 732708)
Originally Posted by DonL
(Post 732707)
There's a qrite up on here on switching out interior for leds, and swapping out exterior lights as well...
Radio there really is no limit, bunch of threads on hereonto that too... As more mileage, we'll that one will be a little harder. Maintenance is a big one, swapping out the exhaust and intake will well the engine breath better, allowing somewhat of a gain there... but there's not too much you can do to these engines, swapping them out will produce better results lol. |
(Post 732753)
As for specifics to the 4doors, I'm not too sure, but it will have the same information, as they are the "same" from 95-05, and I believe there's not many/any different in the interior lights. Other then the roof consoles, which in the end will be the number of bulbs not the bulb difference.
Our trucks have a common problem where the bushings in the door hinges start to wear or break. The door sags, may leak and the constant slamming closed can damage the strike plate and/or the center pillar. If your lucky the fix is simply replacing the hinge bushings and pins as it was with mine. The door gets supported or suspended, the pins are removed, the bushings replaced and then reassembly. Sometimes oversized bushings are in order. Worst case is welding in either location. If you search, there are many threads on this but here is one which includes discussion of the OS bushings:
https://blazerforum.com/forum/paint-...stalled-89003/ Regarding the locks, so you can fully lock all four doors and then all four doors spontaneously pop back open with the electric lock motors? George |
(Post 732756)
| All times are GMT -5. The time now is 07:28 PM. |
