2004 Chevrolet S-10 Blazer No Radiator Drain Plug
I "was" in the process of changing out the coolant in a 2004 Chevrolet S-10 Blazer until I found this...
[IMG]local://upfiles/8930/7DD5103E2B244ADE84100D2AD6C9F96F.jpg[/IMG] This picture is looking up through the raised rubber flap in the passenger front tire well at the bottom corner of the radiator. Now not to ask a stupid question, but is the drain plug broken off? You can see a smaller spout to the right of the neck where the radiator drain plug should be. Is this some sort of redesigned thing to open and close the radiator drain with that requires some sort of special tool? If the radiator drain plug is broken off, how can I get what is left of the broken plug out so I can replace it? |
RE: 2004 Chevrolet S-10 Blazer No Radiator Drain Plug
Nope, not broken off at all. You will need a 1/4" drive extension to turn it. It'll only take a 1/4 turn, any further and the whole valve will pop out. I attached a rubber hose to the nipple on the bottom to direct the coolant into a bucket instead of having it dribble all over the frame.
Nope. I stuck in a 1/4" drive and it never found anything to get into. Strange. I wonder why GM has to make a shade tree mechanic's life so difficult.
Just pull hte lower rad hose.
Yup. That is all that can be done. The job is almost finished. I had to remove the battery to have enough room to get to the clamp.
I can assure you that the drain is there. It takes quite a bit of effort to get the extension to engage. It has the square drive as well as flats for a large screw driver, but only to put it back in. The extension needs to go in to the valve basically from the top of the picture you posted.
Pulling the lower rad hose is another, much faster alternative. |
I'll try that next year when I do a drain and fill. I had to run distilled water about 8 times throughout the cooling system to get all the nasty red "Death-Cool" out. I used John Deere Cool-Gard as the replacement coolant...
http://www.deere.com/en_US/parts/par..._coolgard.html http://www.deere.com/en_US/parts/par...mparisons.html http://www.hitachiconstruction.com/e.../coolants.html Yes it is dyed John Deere Green, lol. But it is NOT regular green coolant. It is a G-05 formulation with SCA already in it. |
You will not find a pet-cock on these newer ones. GM for some reason has left them out of the factory radiators. I ahve run into quite a few GMs now that have the provision for it, but do not have it drilled out for a plug. HTH
When did they do this Korey? I just did a coolant flush on a friends '04 S-10 quad cab and it had a petcock... Don't know if the rad was ever replaced though... Odd...
That's pretty strange. I still see pictures for 2004 with some kind of drain plug but it doesn't look like the usual petcock.
[IMG]local://upfiles/2910/FEA0C3AFF8114BA99275EF7D637A396C.gif[/IMG] |
Those drains are in the block and haven't changed since '85 for the most part.
The picture posted in the first post here shows the petcock as it has been since '96, but maybe they have it sealed off inside. Still looks like it has the 1/4 turn features in the extension... That is very odd that they would remove it... |
You're absolutely right Kyle, I should get more sleep. :eek:
I was looking at the manual for draining the rad and those were the pics thaey showed. I guess what they were suggesting is that you drain the block because there is no radiator petcock, as Koreyhas previously stated. I think I'd go with Tims' suggestion to pull the lower rad hose. |
ORIGINAL: Kordog You will not find a pet-cock on these newer ones. GM for some reason has left them out of the factory radiators. I ahve run into quite a few GMs now that have the provision for it, but do not have it drilled out for a plug. HTH I still wonder what the smaller thing sticking out of the right side of the pet-cock pictured in the original post is. |
Looking at the picture closely you will notice the groove for the metal pin used on the white plastic drain plug is not completely cut out either. I understand what has been said about the 1/4" fitting, but that is usually on the white plastic drain plug itself that would stick out of the pet-cock. In this case, there is no plug apparently and nothing to turn with the 1/4" extension.
I also changed the coolant out in a 2003 S-10 which looked like the picture above except it had the white plastic drain plug sticking out of it (which I carefully removed and replaced with a black plastic aftermarket thumb-turn version). It didn't have the smaller thing sticking out of the right side of the pet-cock as pictured above either. |
The smaller thing sticking out the side is the actual drain. The 1/4 turn white peice of plastic normally seals this off when it is turned in. Once turned out, it will uncover the port and drain. The 'nipple' is there so that you can slide over a piece of tubing and direct the coolant where you need to.
Seems GM liked to mess around with this... Odd. Penny pinching at its best. You know an engineer didn't make the decision to remove such a thing. |
Kyle, I am not 100% sure when they started that pet-cock delete, but I have seen it on allot of new cars of all makes. It is very annoying, but from what I have heard from my radiatior suppliers is they are doing that because the leaking from the pet-cocks have been too much ofa problem so they eliminated it all together. I don't know if that is true or not, but it does make sense, at least on chryslers, because those pet-cocks SUCK!!! They almost always leak after removing them.
