2004 keyless entry
Old Mar 19, 2009 | 09:21 PM
901's Avatar
901
901 is on a distinguished road
Default 2004 keyless entry
just bought 2004 blazer,it came with two keys and no fob,how can i tell if it is equipt with keyless entry or not ?
Old Mar 20, 2009 | 06:51 AM
Covered in other threads.
The RPO code for keyless entry is AU0. If you have it, you have keyless entry.
You could also drop the driver side hush panel (plastic panel under the dash). The RKE module would be attached to this panel directly behind the DLC (data link connector).
Old Mar 20, 2009 | 01:03 PM
901's Avatar
901
Default 2004 blazer keyless entry
does not have rpo code for keyless entry,how difficult is it to install an aftermarket system?
Old Mar 20, 2009 | 08:25 PM
Depends. Something this new, you will likely have to have the BCM programmed for it. But you at least need to check to see if you have the wiring connector near the location of the receiver. If you do not have that, it is not worth it to try to get the factory RKE and you should just go aftermarket. If you have the connector, you could try just getting an RKE module from a junkyard and plugging it in, then getting the remotes and see if it will work.
huntbuck100
Feb 21, 2011 04:32 PM
bootsdsm
Aug 7, 2008 09:45 AM
Whittaker
Jul 17, 2007 08:00 PM
93Miata
24
Nov 14, 2005 10:09 PM
Thrty5thsc
15
Jun 28, 2005 01:40 PM
