2005 blazer-starting problem-new user
hi friends !
I baught used 2005 blazer, i am very much new with chevi blazer, never used before, after long highway drive i park my blazer at my garage and now its not starting, i tried to start but nothing happened, no lights, no sound nothing, key also stuck in ignition and gares also stuck, i feel its just like locked ! i dont have manual also. When i open bonnet then its look like covered. how can i check battery? pls guide me !! i love this car very much !! |
The battery has an insulation blanket around it, but the terminals are exposed. Unscrew both, black first and check for corrosion and then check the battery voltage. Sounds like it is just a battery gone bad.
You should be able to put the transmission into Park unless the shift cable has broken. This is why the key is stuck....gear selector must be Park or Neutral to be able to turn key to Lock and remove. If the selector cable is broken, it is fixable, but not cheap due to the time involved to replace it. What you do is get under the vehicle at the driver's door. There is a cable with a flexible boot on it at the transmission. Push the lever towards the front of the vehicle. This will put the transmission into Park and allow you to remove the key. The engine must NOT be running when you do this. If you have to do this, let me know and then aftewards I can tell you what has to be fixed. Good luck. |
Problem solved!!
Thank you very very much "LannyL81", This is battery issue, battery is gone. I didnt beleive becoz i changed battery 2 months ago. Any ways once again thank you, I replaced battery and now its working fine.
thanx for your guidence !! |
