201 scan tool readings
Hey I'm new to the fourm and lacking much knowledge about this stuff. But i have a 2001 chevy blazer 4x4 with 220xxx miles, has a k&n air filter and thrust exhaust. New plugs wire cap and rotar. My problem is I am getting some codes such as 0155 and 0135 and also a 0499 and 0300. Well I have read about these until i can't see stright, so I decided to barrow a scan tool from a buddy and get some readings at idel and motor warm and see if any of them stand out to you all or any I should be concerned about...
Rpm- 636 Load- 2% MAP- 4 psi MAF- 4.7 g/s Baro- 14.2 psi Spark timing - 15-18 Air fuel ratio- 14.6 That is about all that I thought might be important that it reads, any help would greatly be appreciated, I know a lot of this has probably been gone through in this thread but I don't understand a lot of what I'm reading so I thought if I could get some input on my specific truck it could clear some stuff up. Thanks! |
We will need all of the diagnostic trouble codes, (DTC's) in the order they are retrieved. The data you posted is about 10% of what we need to see to make any kind of analysis. We need as much data as your scan tool will display. A brief description of the symptoms you're having, and the manufacturer of the parts that were replaced, (what brand are they?) would be very helpful.
| All times are GMT -5. The time now is 03:22 PM. |
