#3 spark plug
How the helll are you supposed to change the #3 plug with the damn steering in the way?
I put the socket without anything on it on the plug, then using an ext. from the fender well i can get a good enough bite to pop it loose
I've tried all the ways that are supposed to work, can't get any of them to. I just unbolt the steering shaft, take it off the box, and move it up out of the way. Sucks for sure, but it's not like you're changing plugs every week.
Cleburne how do I unbolt the steering shaft to take it off?
I've tried the other ways and it worked for the 96 but this '01 the shaft is dead center of the plug. |
hey, so there is a plastic container around steering part you need to access.
It's a matter of finding the tabs and spreading open the plastic piece. after opening up like a egg shell I removed it by pulling it down or something to that effect. MAKE SURE STEERING WHEEL IS STRAIGHT. Once open you will see a bolt - Forgot 9/16 or what have you. I removed the bolt then lifted up on steering shaft or PUSHED SHAFT back towards rear of truck. Can't recall if it was telescopic or not. I made sure to then access the plug through the wheel well with truck jacked up on that side. Went right in. I tried all other ways and just bit the bullet and did it this way. make sure it goes back together same way Probably a good idea to use lock tight on bolt when putting it back in. Put plastic cover back on. Search for tune up on site I found info that way on this procedure, hope this helps |
Thanks joejiz, I'll try it tomorrow
If you got your truck up on stands with the front wheel off, jack up the engine just a bit. That will also give you just enough room to get in there through the wheel well with a swivel and extension, and you don't have to remove the steering shaft. Of course if you remove the shaft, you won't need the swivel, possibly even the extension.
I just did this two nights ago. |
buy a socket that has a 5 point end on it so you can slip a open end wrench on it. make sure you slip the steering wheel shaft plastic sleeve up for more room and turn the steering wheel to an area where the flattest part of it give you the most room.
or snap on sells a socket for just that plug, it sells for around $50. I borrow mine from my neighbor who is a GM service manager. maybe you can make a "friend" at a local dealer or buy him lunch to borrow it overnight? good luck it can be done. |
Originally Posted by blazer47
(Post 666368)
good luck it can be done. I use a Craftsman 43322 "flex" spark plug socket, Craftsman 5/8 in. Spark Plug Socket 6 pt. Flex The same basic socket is also available from GearWrench, part # 80404, GearWrench 80404 3/8-Inch Drive Swivel Spark Plug Socket 5/8-Inch The SnapOn one is overpriced. It's an "offset" socket, kind of like one of the deep O2 sensor sockets, but without the slot. Socket, Spark Plug, Offset, 5/8", 12-poin |
Thanks guys for the help.
Another quick question. I changed all my plugs and wires and now it's running rough, I gaped the plugs at .060 like the manual said but the ones I pulled out were gaped at .045. Is this a common problem/ issue |
| All times are GMT -5. The time now is 09:59 AM. |
