-   -   4.3 engine hesitation issues (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/4-3-engine-hesitation-issues-55458/)
magg383 02-15-2011 09:50 PM
I've been having engine hesitation issues with my 96 4.3 blazer since last summer. What happens is when it is humid out, the motor will hesitate slightly at idle and continue thru the power band. Last summer the "service engine" light came on so I took it to a local shop. They hooked up a trouble code diagnosis and told me that I needed new plugs and wires. I had both these replaced and was ok untill weeks later when it got humid out. I did not replace the distributor cap because I it replaced 3 yrs. ago along with a new fuel pump. I'm thinking of replacing the dis. cap because of the humidity issues. Any suggestions would be greatly appreciated!!!:)
blazin734 02-15-2011 10:19 PM
cap and rotor should be changed along with plugs and wires. also fuel filter.
LRV31 02-16-2011 12:32 PM
X2
Also clean the throttle body & MAF.
