4.3 mild to moderate build looking for suggestions
i have a 2001 blazer 4dr 4x4 looking to squeeze more hp out of it....
i will be building a different motor but i want to keep stock stall convertor, FI and minimal machine work (except the normal bore, polish/grind crank, etc...) WILL bore .060 over stock even-fire crank stock style pistons (better than OE and .060 oversized) looking at comp cams 270ahr with .470 lift double valvesprings rollerrockers (will machine heads for screw in rockerstuds) dual-tooth timing chain set port/polish heads intake upgrade SCPI to MPFI pcm programmer my questions: cam? anything better? MUST BE COMPUTER CONTROLLED! can i mill the heads w/o any problems to achieve 10.0:1 compression? ANY OTHER IDEAS/SUGGESTIONS? PLEASE LET ME KNOW!! THANKS!! |
