RE: 4 wheel drive wont work
check your tcase fuse. if its blown, its the switch itself.
i have a 98 jimmy and the buttons on the dash just blink when i go to engage in 4wd and i can hear a click either behind the glove box or kickpanel on passenger side. any hints to the problem here maybe switch or the actuator. thanks
i have a 98 jimmy and the buttons on the dash just blink when i go to engage in 4wd and i can hear a click down by the kick panel on the passenger side. any hints?
wheres the Tcase fuse located
it is in your fuse panel. on my 97 blazer its fuse number 19. spot is marked 4wd. left side of dash,, facing the door.
the fuse isn't blown what else could it be>
You probably have a code stored in your TCCM....you need to groung pin 13 of your DLC and check for codes....if you are not sure what a DLC,TCCM,code or ground is...then do a search on this site it has been covered MANY times.
it is probably the "incoder motor" or the transfer case shift motor (they are the same thing) you can get them from most auto parts stores.
