4 x 4 issues
Old Dec 11, 2010 | 04:46 PM
sffd13's Avatar
sffd13 is on a distinguished road
Default 4 x 4 issues
I have a 2000 Chevy Blazer LS. When I click out of 4wd into 2wd there is a clunking or a thud noise that comes from underneath. I also have a vibration in 2wd after I have used 4wd. Any suggestions or any other previous topics would be greatly appreciated.
Old Dec 11, 2010 | 06:42 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Sounds like a bad U-joint. Have a trusting friend watch for a jumping or clunking one while you slowly alternate between reverse & drive with your foot on the brake.
Old Dec 12, 2010 | 08:19 AM
Sounds like your front axle isn't disengaging properly. How many buttons do you have on the 4wd switch? 3-button == NV233 and 4-button = NZ236.
Why don't you bring it over to my house and we'll get it fixed up before this storm hits! LMAO!
Old Dec 12, 2010 | 05:47 PM
sffd13's Avatar
I'm en route.....lol..... I have the three button switch
Old Dec 12, 2010 | 06:22 PM
I really wasn't joking. I have time. It isn't snowing yet.
A clunking noise sounds more like a problem with the front driveshaft than the front axle engagement. Most of the time, a partially engaged collar in the front axle is described as a clicking noise as the teeth on the passenger side extension axle skip over the teeth in the collar.
Old Dec 12, 2010 | 06:43 PM
sffd13's Avatar
I got a feeling its the u joint in the front but I'm not 100% on that.....I also have to replace the differential cover.... so i have a little bit of a project on my hands
Old Dec 13, 2010 | 09:53 AM
sffd13's Avatar
I have the differential on order and should be here by Tuesday, but I had to order two different sizes and find out which one it is when I take the old one off.
Old Dec 13, 2010 | 11:00 AM
tntfaguy's Avatar
tntfaguy is on a distinguished road
What are you referring to when you say differential? Can you give us a part # so I can look it up?
Old Dec 13, 2010 | 11:32 AM
sffd13's Avatar
Differential cover for the rear.... there is two sizes listed for a 2000 LS
Old Dec 13, 2010 | 01:18 PM
stlwaco's Avatar
stlwaco is on a distinguished road
If you don't have a ZR2 it is the smaller one.
