4wd issues driving me crazy
Ok so my 98 envoy , I took it to the beach as i usually do and go to engage 4wd and just get clicks and flashing lights , so i just started changing parts like a idiot...
so heres what ive changed/found out so far just to get them out of the way Encoder Motor New Reman Switch on Front Diff New Vac switch on TC New TCCM Used Know good Cable is not broken Vac Actuator Good , held vacuum no problem I am Getting vacuum from the engine to the Vac switch on TC When i try to engage 4wd i am getting no vacuum to the actuator So My only thought now . Is it pobbilbe that whatever peice inside the TC that presses the button on the vac switch is broken? or is it just something that could never break ? Any ideas? And yes i reset the TCCM after every part i changed and after everytime i try to engage the 4wd .. i think it just shuts down and dosent even try after you attempt 5 times or so , am i right? thanks -Dan |
Did you pull rhe DTC codes from the TCCM before yyou replaced it
I had a issue the service 4wd drive light would come on all the time the GM prts guy was cool and pluged his TECH 2 scanner and pulled a 3725 DTC code from the TCCM I replaced the switch on the dash and re plumed the vaccume lines the guy that had the 99 s10 blazer and it all missed up put the old TCCM back in and pull the codes any good trammy shop will do it for free if they think they are going to get the job of fixing it they MUST usr the TECH 2 Scanner Good luck |
the 4wd dash light is not coming on , just the lights on the switch ..
im trying to figure out why i can get vacuum to the vac switch but not to the actuator |
pull the vac line and see if it sucks at the acatuator
| All times are GMT -5. The time now is 01:35 AM. |
