-   -   4wd ?'s (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/4wd-s-48253/)
ethanf Aug 24, 2010 12:41 AM
4wd ?'s
the thing under the battery tray.. is it the 4wd actuator? has the male end on the right side that's goin into some springy thing w/ a rubber around it. sorry, i know i suck at explaining these things, but this 4wd is eatin me up. anyways, that actuator or whatever it is is jacked up. is it hard to replace?
nj4x4blaze Aug 24, 2010 05:36 AM
That is the actuator and it's not hard to replace. Remove the one or 2 bolts holding it to the wheel well and then slide the clip up that holds the cable in place and remove the rubber hose that goes into the actuator. Very easy to replace.
jbsnowboarder16 Aug 24, 2010 03:16 PM
They tend to go bad, the rubber diaphragm will spit and cause the actuator to lose complete "sucking power" thus causing your 4WD to not engage
davedidit Aug 25, 2010 12:32 PM
Yup EZ to remove and replace:icon_playing:
ethanf Aug 26, 2010 09:39 AM
awesome, thanks guys. soon as i get my chain tightened on my raptor i'm gonna try to replace it.
