4x4 switch not working
Just joined today & need help bad. My wife just put a new trans in 2000 Blazer. First snowfall tried to put it back in 4wd or AWD and nothing. In the shop now. Shop said not under the trans warranty. What are some of the possibilities and is it worth fixing. My wife loves her Blazer and we use it to tow M/C and pop-up. Please help.
*Moving to 2nd Gen Tech* - The New Member Area is for new member introductions. Technical questions belong in the technical sections.
Is your 'service 4wd' light on in the dash cluster? If it is, you should look into getting the codes scanned by someone with a scantool capable of reading the TCCM codes. That will give you some direction to go in.
If not, then I would start by checking the electrical connections at the TCCM which is located behind the passenger side kick panel just in front of the passenger side door under the dash.
mjw1991
02-24-2013 10:18 PM
tdbone1
75
01-10-2013 03:27 PM
chrisblaze
12-06-2009 12:27 AM
