4x4 will not stay engaged
I have a '99 Chevy Blazer that when I put the 4x4 in 4hi or Auto 4x4 the light flashes until I put in Reverse then when I go into Drive it flashes.
Also noticed sometimes when I come to a stop the light comes on solid then as soon as I move it flashes. I seen on some other sites that the electronic module connector might be corroded, I took it off and clean it still doing the same thing. does anybody out there know what this may be? |
Hello and welcome to the forum. You should post your question in the "second generation" section of the form. You'll get a much better responce if you do. This section is to introduce yourself to the forum. My Blazer is 2wd so I can't help you but good luck with it and welcome again.
| All times are GMT -5. The time now is 10:45 AM. |
