90k
Hey everyone. My truck is going to hit 90,000 miles tomorrow. Is there anything special I should be doing/checking? Oil/trans/Coolant were all done recently. Differentials/TC/Brake/Power Steering were all done in 2009. I got a card in the mail a few months ago from a business I am no longer doing business with (the one that tried to charge me $1200 for wheel bearings in February) that tells me that I have to bring the truck in for a 90k mile service but says nothing about what is in a 90k service or what it costs. What does a 90k service involve and can I do it myself? Thanks.
You know in the owners manual they have a recommended service list. If it doesn't go to 100,000 miles you can refer back to the 45,000 service.
But, you know, I change oil & filter regularly. I check all my fluild levels at each service. I change tranny fluid when I notice it starting to turn dark red or it starts smelling. Before I added a B&M SuperCooler I would change the ATF & filter every 30,000 to 40,000 miles. Diffs & transfer case I change when I notice them looking or smelling bad. Other than that I just drive them. We have 143,000 miles on our Blazer 4x4 & my wife commutes 120 miles a day with it. I just stay on top of maintenance. Check belts, air filters, I run an injector cleaner every so often through the gas. I check my water hoses closely. Sometime I just stand & stare at the engine just looking to see if I see anything not right. I always watch for leaks, things like going to the store & come out & fluid under my rigs. As an old retired & tired mechanic I'm not real big on these maintenance schedule things. We drive used cars & drive them sometimes to 300,000 miles or more. We just watch things. My wife is real good about paying attention to different noises or conditions. But she is a daughter of an old, retired, tired mechanic so she is pretty aware. |
Originally Posted by 4x4blazerguy
(Post 331283)
But, you know, I change oil & filter regularly. I check all my fluild levels at each service. I change tranny fluid when I notice it starting to turn dark red or it starts smelling. Before I added a B&M SuperCooler I would change the ATF & filter every 30,000 to 40,000 miles. Diffs & transfer case I change when I notice them looking or smelling bad. Other than that I just drive them. We have 143,000 miles on our Blazer 4x4 & my wife commutes 120 miles a day with it. I just stay on top of maintenance. Check belts, air filters, I run an injector cleaner every so often through the gas. I check my water hoses closely. Sometime I just stand & stare at the engine just looking to see if I see anything not right. I always watch for leaks, things like going to the store & come out & fluid under my rigs. As an old retired & tired mechanic I'm not real big on these maintenance schedule things. We drive used cars & drive them sometimes to 300,000 miles or more. We just watch things. My wife is real good about paying attention to different noises or conditions. But she is a daughter of an old, retired, tired mechanic so she is pretty aware. The only leak I know of is a very slow oil leak, possibly out the rear main seal (so I was told) since the oil pan has a film of oil on it, but I have never had to add oil between oil changes since I am not noticing a drop. I already had both sets of oil lines replaced. Since it is so slow of a leak and a difficult fix, I really don't want to have an long, expensive repair on my hands so it is not worth fixing. When the oil lines were leaking in 2008, some idiot I know put stop leak in the oil (which obviously didn't work). Never used anything like it again. The only additive I used to use before this previous oil change was Lucas, but I didn't use it this time since I used Royal Purple 10W-30 as an experiment. I think I am going to try 1/2 a qt of Lucas at the next oil change just for the heck of it since the Royal Purple seems to work fine. |
Sounds like your in great shape maintenance wise. I say just drive it & enjoy the ownership of a good SUV, I enjoy ours & use the heck out of it. It sees a lot of off-road & highway both. I think they are great trucks even with the problems they can have. Chevy's I think ride, handle, & drive the best of any of the SUV line. I know people with $65,000 SUVs that in my opinion aren't any better.
(Post 331337)
Actually, I don't think these trucks are full of problems. Sure, the front end, intake gaskets and 4WD can be a pain in the a**, but none of those are serious enough to actually disable the vehicle and are usually easy fixes. Also, I am (if I can put it in words) a short computer nerd. Getting into this truck is easy. You don't need to take a climbing course or take Climbing merit badge at summer camp (I did in 2007.) just to get into it. I also drove an 03 Tahoe and a 93 full size Blazer a while back and those were like flying a 767 or 777 on flight sim. They were hard to handle, especially on highways, narrow country roads and parking lots. I even had trouble sitting close enough to the wheel to reach the pedals and see out the windshield. If I could compare the Jimmy to a plane, I would call it a 757-200 because it is long, futuristic (the newer models don't look like late 90s trucks. They aren't "boxy" enough like the full sizes.) and thin. It might be a bit hard to maneuver in parking lots and narrow mountain roads, but on highways, it is the best. It is the right size truck for me. I have no trouble reaching the pedals or seeing out the front (and I am not even sitting in the airbag danger zone). Yea, it is a great truck. I have put 32,000 on mine (just hit 90k tonight) and I would find it hard to drive anything else. |
| All times are GMT -5. The time now is 03:11 PM. |
