94 blazer 4x4 stock hitch onto 99 blazer 4x4
Old 11-29-2012, 05:24 PM
tdbone1's Avatar
tdbone1 is on a distinguished road
Originally Posted by nunya
I know my tube style hitch was from a 95-97 with the style bumper in cleburne red's pics and I had to make slight notches in the side plates to clear on my 98 with the step style rear bumper. I have to look to see if its on the outside or inside of the bumper brackets though (wife ain't home at the moment so theres no truck to look at)
appreciate if you get me some more info.
man i hope this hitch fits
i got it from a salvage they might let me exchange.
not sure
Old 11-29-2012, 05:56 PM
nunya's Avatar
nunya is on a distinguished road
just skimmed through my photobucket a little to see if I could refresh my mind there, the hitch IS on the outside of the bumper brackets (the bumper brackets sandwiched between the hitch and the frame) and I do remember having to persuade things a little to get into place (use of a jack on the hitch and kicking the bumper)
I never measured the notch I had to make unfortunatly, just kinda eye-balled it then hit it with the torch with results that ended up basically perfect
the end plate came down at a strait "\" angle and I just basically had to make it a "L" shape to clear the bumper differences
Old 11-30-2012, 08:10 AM
tdbone1's Avatar
if i have the bumper off the frame and i only slide the hitch onto the frame it fits like a glove and the sides (ears) of the hitch are not flared out
the ears of the hitch make full contact over the frame rails on each side.
now the bumper sides (ears) fit exactly over the frame rails to.
so since both the hitch sides (ears) and bumper sides (ears) are the same length apart they dont want to slide over each other if one is installed over the bumper first
if i install the hitch ears over the bumper ears they flare out
it i install the bumper ears over the hitch hitch ears then they flare out too
is this normal
Old 11-30-2012, 10:23 AM
tdbone1's Avatar
just wanted to leave some info about the hitch experience
the hitch ears go in the middle of the frame and the bumper rails
the actual bumper has slots on the bottom and on the top under the rubber step that are slotted
so what you do is bust all 4 nuts and bolts per side loose and then the bumper rails you bolt to the frame and hitch rails so they are in place first
then you re-tighten those 4 bolts per side (not the ear bolts (those are already tightend) but the bumper bolts to lock the actual bumper in place after you have its placement correctly positioned
then its a piece of cake
so all is good and thanks for all the help
Old 11-30-2012, 05:46 PM
cleburne red's Avatar
So, you were able to bolt the hitch off a '94 onto your '99? Good to know they will interchange.
Old 11-30-2012, 06:53 PM
tdbone1's Avatar
yep that hitch worked out pretty good but another part i got did not.
i got a tire lift for the spare and the new one is about a couple inches longer and does not line up with the holes above the tire
i can get one bolt in but i sure would like to get both
probably will have to drill another hole to make me feel safe driving it.
lionel2
09-06-2012 11:27 AM
slowsinglecam
06-14-2012 10:12 PM
1996BlazerGute
08-03-2011 10:20 PM
jimn1
09-27-2008 11:17 PM
lorner
03-21-2006 04:01 PM
Quick Reply: 94 blazer 4x4 stock hitch onto 99 blazer 4x4
