-   -   95 4x4, 4.3, Vin W, OBDII, CMFI...PCM question (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/95-4x4-4-3-vin-w-obdii-cmfi-pcm-question-10647/)
disturbedgame 05-08-2007 09:01 AM
Truck won't stay running. Replaced most sensors already, finally checked voltage to the sensors, from PCM. No voltage going to TPS, or MAP Sensor. Haynes manual says I should have 5 volts to each with the ignition on, but I have nothing to these 2 sensors. My next guess is the PCM is spent. everything else checks out fine. Found a PCM that comes programmed according to my VIN#, from NAPA for $150, so it could be worse. Just want someone else's opinion. anybody got any ideas before I order the PCM?
swartlkk 05-08-2007 10:32 AM
RE: 95 4x4, 4.3, Vin W, OBDII, CMFI...PCM question
Well, you could probe the wires at the PCM that send the voltage to the TPS & MAP sensors. That may be were I'd go next before coughin' up the $150...
I don't have my references with me at work, but I may be able to get you the cavity numbers on the PCM for the wires you need. Plus I'll take a look at the wiring diagrams to see if there is anything else in common with those sensors that you may be able to check.
