95 Blazer ABS Fuse
I am trying to find what fuse works the ABS and where it is located. The ABS light is on and when coming to a stop the ABS is kicking in causing the brake pedal to pulsate. I need to disable to ABS for a couple of days until I can pull the tires and check the wheel sensors. I have a Haynes manual and it is useless when it comes to electrical.
In my blazer the side fuse bye the drivers door its number 10. i had the same problem. I went to chevy they said i needed 2 new front hubs. I bought timken and that solved my abs problem. But if u pull the fuse u will have reg brakes
I had also gone to chevy and replaced both hubs with timken....8 months later in the same boat....pulled the fuse
Thanks. I saw that the fuse said brakes, stupid me, I thought is was for the brake lights. I wish I had the extra cash to drop for a set of Factory Service Manuals.
