95 blazer CEL light flashing
A fault with any of those can cause a misfire, but those are not the only things that can cause a misfire. In your first post you mentioned sparks around the distributor cap: that could indicate a probem with the the cap, rotor, wires, or spark plugs. Replacing the cap & rotor would be a good place to start. These things are real fussy when it comes to secondary ignition parts, so make sure you use AC Delco only. Put a dab of silicone dielectric grease on each terminal, inside and out, of the cap.
BipolarExpress
07-24-2012 08:45 PM
schollianmj
11-18-2011 04:46 PM
Blaze01
16
03-05-2011 10:22 PM
jman_08
06-25-2008 07:27 PM
