-   -   95 blazer, I have a bug in the electrical system (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/95-blazer-i-have-bug-electrical-system-81448/)
Spree Sep 6, 2013 01:05 AM
Originally Posted by shleprock (Post 599571)
First off, I havn't changed anything, it just blew one day while I was driving! The gauges must be on this fuse, because they all went dead when the fuse blew! Do the switches on the door jam just pop out from the front? Is it posible that it's a bad compassitor, and thats why the light slowly goes out??? How about the ignition itself?
Not sure....just through'n things out there...if all your gauges went dead, check your ground wire, it's on the left side of the dash up by the fire wall when sitting in the drivers seat. It also goes through the fire wall and into the engine compartment, check there too.
When I pinched mine all gauges went dead and a lot more (could be there). I've had ground wires go bad before for no reason.
Door jam switches should come out from the front and "no" on the capacitor.
Alphadog Oct 21, 2013 12:05 PM
Hi Shleprock, Did you ever find the cause of the blown fuse? I am having the same problem with the same fuse. Started a couple days ago. And I have a 95 4dr 4wd Blazer Lt.
thx
richphotos Oct 21, 2013 12:28 PM
*moved to lighting and electrical*
