95 blazer rough idle
Old Feb 22, 2009 | 10:18 PM
1badblaze's Avatar
1badblaze is an unknown quantity at this point
Default 95 blazer rough idle
i have a junkyard motor in my blazer and it has a rough idle but no cel. should it be smooth at idle as i know it has a balance shaft. im worried the valve guides are bad as the last motor had oval shaped guides when i tore them down. it has new plugs and wires. new cpi spider and pump. and a new cap. unknown on the rotor as it was with the junkyard motor. is this 4.3 known for vibratioor what ns
Old Feb 22, 2009 | 11:29 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default RE: 95 blazer rough idle
It should idle pretty smooth. You may have a worn distributor gear, stretched timing chain or other issues. Hard to say without doing complete diagnostics. No error codes doesn't necessarily mean everything is working right.
blazerguy22
Nov 14, 2013 11:50 PM
blazer chris
Dec 8, 2011 09:56 AM
nhguy261
Dec 30, 2010 01:41 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
c10jm
Aug 12, 2008 05:34 PM
