-   -   95 Blazer Water Pump (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/95-blazer-water-pump-64489/)
btmbass 10-28-2011 10:07 PM
Hey everyone. So I've got a coolant leak somewhere between my radiator and engine right by the fan, it has to be the water pump right? It seems to only leak overnight, while running nothing leaks.
I've replaced water pumps on caprices before and it pretty easy, how hard is it on the blazers?
chris015 10-28-2011 10:08 PM
Make sure its not the thermostat housing running down.
Remove fan shroud,fan blades,belt etc...should beable to get right to it.
xgiovannix12 10-28-2011 10:11 PM
check your hoses also before heading for the water pump
Thogert 10-28-2011 10:16 PM
Yeah, not too hard. I did it afew months ago. Hardest part was getting the round double ended screws out of the old water pump.
chris015 10-28-2011 10:19 PM
I tell u what...i am pro at waterpumps on 1st gens..
My 1st blazer i had,had over 600k on it..I redid 9 water pumps in 2 months. They would hold for a few,then leak again. to find out the block surface was warped. I stuck a ruler against it and could see light! So i finally fixed it.2 gaskets on 1 side,and 5 on the other,and tightened it as tight as i could possibly get it. didnt leak for 5 months,then i sold it.
xgiovannix12 10-28-2011 10:24 PM
lol wow 5 gaskets ? you couldnt seal it with black rtv?
Thogert 10-28-2011 10:27 PM
Oh, and by the way btmbass. My water pump would leak whilst running.
I found this out on a 450 mile trip and while getting gas I came out of the station and saw that my blazer was bleeding! Orange coolent all over the bottom of the truck.
Something to think about.
