95 chevy blazer rusted out feul lines
My 95 Chevy Blazer is in need of new fuel lines(rusted).It is 4.3L V6 4WD CPI Vin. W engine. They are rusted just after sending unit at the bend going towards fuel filter. I was wondering if anyone has any luck finding replacement for a reasonable price if so where? Or a repair solution? Any help would be great.Thank You
*Moved to 2nd Gen Tech* - Please read the descriptions of the forum sections and choose the most appropriate section for your question. Also, please be patient and do not double post your question. Thanks!
I had the same problem with my 2000 Blazer. The high pressure and return lines snake in between the frame and the body. The solution that my local auto parts store, was to make up a set of nylon fuel lines. The fittings that are needed are pressed onto the nylon lines. Cut the steel lines into sections so the total length of the lines can be measured with the bends. Once you have the completed lines its very easy to install the lines. I believe the only way to install steel lines is to raise the body off of the frame. There is no way to route the pre bent lines any other way. Good luck
