95 Jimmy a/c problem plz help
Old Jul 10, 2010 | 06:41 PM
josh77888's Avatar
josh77888 is on a distinguished road
Exclamation 95 Jimmy a/c problem plz help
Alright ive been reading some of the other pages about a/c problems. But still can't get cold air.
I bought a 18 oz can of EZ Chill from advance auto parts and it has the gauge with it. So i hooked it up. Clutch wasn't kicking on so i jumped the low side switch and started to fill it.
I think i over filled it at first. It was climbing to about 45psi on the gauge or so, but it was blowing a little cold air. It was running in the ALERT section of the gauge which worried me, so i drained some of it out. Now im back to square one WARM air.
Now i have it running with Max a/c ON at 37-39 psi. On the bottle it says to be in the blue section and that means correct charge.
It stays at that pressure but its still blowing warm air. I dont know if i did something wrong or what. Can anybody help me out? Im not sure if i need to add more or what.
Old Jul 11, 2010 | 12:17 AM
josh77888's Avatar
Also do you guys think it could be the blend door actuator? I did a little more searching and seen that people were having trouble with warm or cold air and the problem was that actuator, but i really didnt want to pull the dash out being that its a 95 so i cant do the glove box trick
also another thing to add is i had it on max ac and it felt like a VERY little cool air was coming from the floor vents, but warm air from the regular vents....is the actuator the problem???? please someone help, very tight on money and i can't afford a mech at this time.
Old Jul 11, 2010 | 09:13 AM
1998MSO's Avatar
1998MSO is on a distinguished road
Does your accumulator get cold when the A/C is on? If it does, your A/C is working OK but your blend door probably is not.
Old Jul 13, 2010 | 08:14 AM
josh77888's Avatar
its not cold, its cool. I checked my sister's car and my mother's car AC and there Accum. is VERy cold and ac freezes u out.
Could there be air or moisture in the system? thats whats causing the problem??
Jimmy76
Feb 22, 2013 05:12 AM
02BlazerS.jersey
14
Mar 16, 2012 11:39 PM
blazerguy22
Oct 15, 2009 08:57 PM
cr8390
Nov 7, 2008 08:45 PM
blazergirl15
Sep 7, 2005 05:18 PM
