95 s10 blazer 4x4
Old May 17, 2011 | 06:16 AM
mattman's Avatar
mattman is on a distinguished road
Default 95 s10 blazer 4x4
I am new to this. My son was driving the blazer and it died on him. I changed out the fuel pump and still nothing I am not getting fuel. I checked the fuse and the relay. Could this be the cam positioning sen. or what please help
Old May 17, 2011 | 07:00 AM
*Moving to 2nd Gen Tech* - The forum help & suggestions center is for forum/software related help.
How have you determined that you are not getting fuel? Are you using a fuel pressure gauge? If so, what is the pressure with the key on, engine off? It should be 55-60psi and the pressure should not drop below 50psi for 10 minutes after the pumps shuts off.
Old May 17, 2011 | 07:27 AM
mattman's Avatar
The fuel pump does not run, checked and have power to it
Old May 17, 2011 | 07:42 AM
mattman's Avatar
The pump does not run when the key is turned on but i have power to the pump
Old May 17, 2011 | 08:23 AM
If there is +12V power and ground to the fuel pump connector, the only other cause for a non-working pump is the pump itself.
Old May 17, 2011 | 08:46 AM
mattman's Avatar
thats what i thought and changed it and still nothing and i thought that it was bad so i replaced it for the second time and still nothing could it be the cam pos. sensor?
Old May 17, 2011 | 09:47 AM
No, I do not think it is the cam position sensor.
As I already said... If you have +12V and a good ground to the pump, the pump should run provided the pump is good. Period, the end. You either do not have +12V, a good ground, or a good pump if the pump is not running.
Dallas1970
Feb 22, 2019 05:05 PM
94BlazerGirl
Aug 28, 2014 06:14 PM
rfine67
Aug 13, 2011 01:04 PM
RickBlazer
Jun 23, 2011 04:59 AM
ricky
Jul 22, 2010 08:04 PM
