96 Blazer problems after another.
Hey guys i haven't been on here for a while. But right now i have serious problems with my blazer well gave it to my sister but anyways, it keeps having problems starting the car cranks but takes a while to start, i think its a bad or clogged fuel filter, i already have the replacement for the filter but when i went down to replace it it has both sides stripped, i tried pretty much everything to try and loosing it but it made it worse now its completely rounded on both sides. Any ideas on how to get it to loose. i might just have to replace the entire fuel lines but i don't really have the money for it.
Also now there is a really bad whinning noise when i drive the faster i drive the louder it gets, i am thinking the bearings need greasing but i am not so sure could that cause a whinning noise, also the brakes feel really hard when pressed, i am also thinking that the abs is starting to tighten the brakes which i am not really sure about. I am no mechanic. I dont have time to take it anywhere, here is a question Can the ABS cause the brakes to tighten? and in which create the whinning noise, please help me. like i said i gave it my sister still running smooth and now its all problems. Thank you in advance, any ideas will help. |
As far as the ff is concerned, penetrating oil and tap the connections aggressively. Remove the skid plate that covers the transfer case that will give you some extra room to work. Vice grips are your new best friend. Once you have remover the old ff. Using a hack saw carefully remove JUST the flare on both sides. Slide new nuts on to the lines and re flare the ends. You should have enough play in the lines to get it all back together. If not simply lossen the first mount after the ff.
Don't forget new o rings! Good luck report back! |
As far as the whinning. Start with a bearing repack . Replace any bearings you find to be fouled.
2wd or 4wd? If its 4wd you may even want to replace the front hub assemblies all together. Unfortunately they are a little steep. They range between $80 and $100 each. On a side note. Bad hubs may be tripping the ABS. Just a thought. |
If your sister was monkeying around with the 4x4 buttons your front axel could be engaged or half engaged. If you want you can take the battery out dissconect the actuator and push the cable all the way in. Bet this stops your whinning.
Thanks for all of your replies, i just didn't know what to do with it so i finally ended taking it to the mechanic, he said it might run about 800 dollars or so, he's gonna replace the fuel pump, and filter. Full tune up. Diagnose and repair the abs system. and a few more things that is wrong with my truck. Hopefully he gets it done by the end of the this week. Thank you all again.
The hard starting could be due to a leaky spider assembly, so before you go throw parts at it make sure you or the mech tests the fuel pressure. Fuel pump might be perfectly fine. And my guess is the Mech is going to put a crappy Airtex pump in there and in 6 months you're gunna be back on here wondering why it doesnt start. So just a warning to help keep the headache away.
Fuel filter problem is an easy fix
Get a tube cutter cut the lines as close to the fittings as possible.get a piece of 6-8 inch rubber hose and an universal inline filter.Get a flare tool put fare on both ends of the metal line.put the rubber hose on each end of the tube and secure with hose clamps.Put your filter in the middle of the 2 hose peices and clamp each end down.It will cost you total about $12 done.get a second opinion on having your fuel pump replaced $800 is a bit steep for what your mechanic wants to charge you.
Originally Posted by 97cherryblazer
(Post 545863)
He was gonna dignose it after, huh, I really don't like this guy. I'm happy for you that it's running.
I have never heard of an abs engagement described as whinning. Hard brakes and whistling maybe booster line? All this change then diagnose is some scary stuff to hear. How much was the pump and spider from the dealer? |
Originally Posted by spittybays
(Post 546081)
| All times are GMT -5. The time now is 07:37 AM. |
