97 Blazer! Do I have to bleed the fuel lines
Hi Forum,
after removing my cylinder head and fixing my valves seats. I put all together.
I am assuming that al gasoline in the spider has been vaporized.
Do I have to bleed the fuel line??? The engine won't start after putting all back together?
Thank you for you help.
BR
Bob
BR
Bob
i think all you have to do is let the fuel pump do it. cycle the key like 5 or 6 times. each time you should hear the pump come on and run for a little bit and then shut off. do that a few times and see if it will start then.
Thank you Twip.
On the fuel line on top of the upper plastic intake there is a connector to measure fuel pressure. I pushed the valve with my finger nail and air came out.
I will follow you procedure and will see if it helps. I assume I am having air in my spider.
Hope your proposal helps.
Thank you.
BR
Bob
Thank you.
BR
Bob
I have removed on of my new spark plugs after I have exceuted your proposal
The spark plug was still dry. Only some light gas fumes on the plug.
I wonder how I get the fuel system running again and get the air out of the system.
Thank you for good tips in advanced.
BR
Bob
BR
Bob
kevinph
18
07-15-2018 10:56 PM
702Blazer
12-09-2011 08:57 PM
Dan 128
13
06-09-2010 08:06 PM
soundguy
09-11-2007 03:05 PM
