97 Blazer! Do I have to bleed the fuel lines
Hi Forum,
after removing my cylinder head and fixing my valves seats. I put all together. I am assuming that al gasoline in the spider has been vaporized. Do I have to bleed the fuel line??? The engine won't start after putting all back together? Thank you for you help. BR Bob |
i think all you have to do is let the fuel pump do it. cycle the key like 5 or 6 times. each time you should hear the pump come on and run for a little bit and then shut off. do that a few times and see if it will start then.
Thank you Twip.
On the fuel line on top of the upper plastic intake there is a connector to measure fuel pressure. I pushed the valve with my finger nail and air came out. I will follow you procedure and will see if it helps. I assume I am having air in my spider. Hope your proposal helps. Thank you. BR Bob |
I have removed on of my new spark plugs after I have exceuted your proposal
The spark plug was still dry. Only some light gas fumes on the plug. I wonder how I get the fuel system running again and get the air out of the system. Thank you for good tips in advanced. BR Bob |
Do you hear the pump turn on when you turn on the key?
yes
after charging the batt I could it start. BR Bob |
| All times are GMT -5. The time now is 07:07 PM. |
