-   -   97 blazer hard start (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/97-blazer-hard-start-12787/)
HoppinS10 09-02-2007 01:43 PM
Ok I have diagnosed that there is a significant drop in fuel pressure after the engine is turned off. I just removed the top part of the intake and was wondering if anyone has any input for me as to what component or components are at fault. Is there anything I can test for while the top intake cover is off?
swartlkk 09-03-2007 04:49 PM
RE: 97 blazer hard start
I'll reply here instead of in PM. I hope you don't mind me quoting your PM.
PM from HoppinS10:
Hello again. I posted a question reguarding the fuel spyder in the 2nd gen section. I got the upper intake off and i believe I need a new spyder assembly. Is there any way to test this? I do see some fuel pooling in the intake and I also smelled fuel as soon as I pulled the upper intake off. I see that you had posted some part numbers for GMPD.com and was wondering how long the shipping actually takes. I can get the updated mfi conversion kit from advance auto for about $240 with my friends discount. If this is the part i need, the original o-ring gasket can not be resused? is it different?and is the new bracket absolutly necessary?Also is the fuel pressure regulator part of this spyder assembly? if not I might as well get a new one because the truck has 150k on it.
Thanks again
Doug
Ok. So to answer some of the questions both in your PM and in the post above... A lot has been answered in various other posts, but I'll reiterate for you. For the MFI conversion, you only need the updated spider assembly (which includes the fuel metering body, fuel pressure regulator, and all 6 MFI injectors). The updated spider is a direct replacement for the SCFI spider. Nothing else needs to be changed. I used genuine GM parts when converting my old Bravada and since I was replacing my lower intake manifold gaskets at the same time, I had replacement o-rings for the upper plenum seals. I'm not sure why Advanced Auto's website is calling for replacement of the bracket and gasket pack. The gaskets (o-ring type seals) really only need to be replaced if they are damaged. If, after inspecting them, you find them to be defect free, then it is not necessary to replace them. I used a bit of clean motor oil on all of the seals to ease assembly.
If you have the time, I am interested in seeing what they think is different about the stock bracket and their 'updated' one. The MFI spider I installed had eccentially the exact same metering body as the older SCFI spider. The only difference was that instead of having the electronic injectors housed in the metering body, the MFI spider moved them out to the intake runners in place of the problematic poppet nozzles.
GMPD.com took FOREVER in my experiences with them. Granted I have only used them twice, but with alternatives like RockAuto.com or my local AC Delco distributor, I'd rather not use GMPD.com other than for their online catalog.
HoppinS10 09-03-2007 06:25 PM
Kyle, Thanks for your input. I did look on that RockAuto.com site and i see that the mfi conversion on there is also calling for the new bracket. Might just be a way for them to make a little more $. It looks like I am going to get this assembly from RockAuto.com because it is pretty well priced and I really do not have the time to let this thing sit and wait for parts to come from GMPD.com
Thanks Again
