-   -   97 chevy blazer door hinges (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/97-chevy-blazer-door-hinges-101451/)
Jacksmith 04-06-2020 06:54 PM
have 219k mi on 97 blazer and have to replace door hinges for 2nd time in 6 mo. Is it advisable to weld reinforcing washer on jamb hinge same diameter as pin to keep door level?
Also neutral safety switch went out on same blazer, do u have to replace the whole column or can u just replace the 2 gears that tell the vehicle is in park and will allow u to remove the ignition key?
Mods 04-07-2020 12:39 AM
what tranny. if its a manual i have no clue if its an automatic its a 5 minute swap out of the neutral safety switch on the lefthand side of the transmission
Jacksmith 04-07-2020 01:59 PM
automatic
Jacksmith 04-07-2020 02:01 PM
key will not come out of ignition when in park, was wondering if there is another safety switch on column?
puttster 04-10-2020 09:43 AM
That happened to my 02 when I was under there working on brake light I somehow blew a fuse. Key got stuck.
On edit: that might have been on a 1999 Lexus, not a 2002 Blazer...
