98 Blazer No Floor Heat
Old Aug 19, 2011 | 04:20 PM
  #21
warthogdriver's Avatar
tpolzin....very cool take on this fix. sounds much cleaner than what i did.
Old Oct 5, 2011 | 08:24 AM
  #22
Lucigrl's Avatar
Lucigrl is on a distinguished road
Thank you everyone for your help on this. I did the job myself in about 4 hours. I now have floor heat for my tootsies :-) One thin I did notice is that I get air out of the defroster too when it is in the floor only mode. Is this normal or is there another problem?
Thanks
Luci
Old Oct 5, 2011 | 08:34 AM
  #23
pettyfog's Avatar
It's both normal and a very good thing.
Imagine a very cold day and having to switch output to the windshield to keep it from icing up.
Old Oct 31, 2011 | 10:10 AM
  #24
Lucigrl's Avatar
Default heat positions
After replacing the floor heat flap I am now finding that the floor position only and the floor/defroster positions are the same with no difference. Can someone guide me to what is causing this new problem?
Luci
Old Nov 2, 2011 | 07:53 AM
  #25
airmcnair09's Avatar
airmcnair09 is on a distinguished road
mine too. any ideas?
Old Nov 3, 2011 | 10:52 PM
  #26
Lucigrl's Avatar
Yes, you & I both installed the flap wrong. I fixed mine. Took it all apart again & found that I didn't install the flap correctly. There is a hole that the trailing end fits in to. You have to put the diaphragm end in first while creating a slight bow into the flap and at the same time pushing that trailing end into the hole. Once you do that you can connect the diaphragm end together. Trial & error on my end discovered this. Mine works perfectly now. Be sure you put a small amount of lube on the trailing end.
Luci
Old Nov 8, 2011 | 02:03 PM
  #27
anyone have a part number for the flap
Old Nov 14, 2011 | 08:45 AM
  #28
Marcin's Avatar
Marcin is an unknown quantity at this point
Now I have the same problem with floor vent. I am afraid only how to change the flap. It looks horrible to remove all dashboard.
Old Nov 15, 2011 | 03:58 PM
  #29
Lucigrl's Avatar
Just follow all our posts. I did it.
Luci
Old Nov 15, 2011 | 04:00 PM
  #30
Lucigrl's Avatar
ANother thing, you probably only need the flap & not the gear. The flap breaks at the flap/gear connection. Gear can be re-used
