-   -   '98 Blazer, Only the dash speakers work? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/98-blazer-only-dash-speakers-work-36547/)
xderkax Nov 2, 2009 07:49 PM
Hello, recently got this '98 blazer from my uncle, everything running well, except noticed a problem when I fired up the radio today. Only the dash speakers are working. All 4 doors do have a speaker, I took each panel off to confirm, they just don't work. I tried messing with the settings on the radio just to make sure it wasn't anything there, no luck. It's a stock radio as far as I know. I talked to my grandfather about it, he seems to think there is a wire loose.
First, has anyone else had this issue? Second, how would I go about seeing if a wire is loose? I don't have much of an idea at all about the wiring, but I could figure it out if pointed in the right direction.
Thanks for any and all help!
- Derek
Awesome Nov 2, 2009 10:14 PM
I currently have one speaker that doesn't work (suspect it's part of my electrical problems... taillights don't work and fuse blows) but check the wires behind each speaker and make sure they are plugged in. Also check the wiring that comes through the door hinge area and make sure they aren't being pinched.
