98 Blazer Rear End
Im trying to figure out what the Rear end ratio is for my 98 s10 blazer 4X4
Thanks much! =] |
https://blazerforum.com/forum/steering-suspension-drivetrain-36/rear-end-gear-size-7-5-8-8-1-2-a-28619/
If you open the glove box you will see a mess of these the digit codes. About the 4th or 5th row over you should see a GU6... |
Hey! What Tony H didn't tell you that the GU6 refers to the 3.42 ratio! Most likely with the 8.5 ring gear-the best of the stock bunch:stout and good fuel economy! But I don't know the other axle codes...sorry! W3
thanks for the info guys!
but i didnt see anything with a GU6, all i found that started with a "G" was GT4 or G80 |
GT4 is the code for 3.73 and G80 is the code for the limited slip/gov-lock differential.
i figured it out, 3.73 Ratio = GT4 : G80 = limited slip.
If anyone find any info other wise please feel free to correct/inform me =] |
Originally Posted by step66
(Post 364152)
| All times are GMT -5. The time now is 06:11 AM. |
