98 Blazer stock rim size
I broke a upper ball joint yesterday and something grinded against the rim. The lip is there but one spot has kinda a dent in it. I'm not sure if I trust it or not. I have the stock swirl wheels. I found 4 on craigslist for $200 and they are 15x7 stock GM swirl wheels off of a 1998 S10. I just wanna make sure they are the same as mine before I buy them.
youll get more response in a more appropriate thread (gen tech or wheels an tires).
As far as i know all s-10, s-10 blazer, jimmy, and s15 sonoma rims are interchangeable throughout all years with the only difference being the offset between 2wd and 4wd models. like I sad tho check through other threads, others on here know lot more than I. |
+1 to above Neb
*Moved to '2nd Gen Tech'*
I think $200 is a bit much unless they are like new
look for a set of Camaro 15x7 (iroc style),I just picked up a set for $60 |
I got a set of the factory rims for a 2wd i'd let go for alot less than $200. They are just the standard swirl kind. Not the fancy looking deeper looking ones.
| All times are GMT -5. The time now is 07:18 PM. |
