98 chevy blazer problems PLEASE HELP any help would be appreciated
ok heres the deal, it turns over wont start, the pump is running when this happens. it shuts off of me at times like when i come up to a stop light or in drive thru, sometimes it starts back fine other times it leaves me sit for a while. this problem started near the end of last summer, and as weird as this may sound when its cold outside it doesnt shut off on me and is still hard to start but in the summer and now that its starting to warm up shuts off frequently but is still hard to start...here is a list of parts i have already replaced....
fuel pump
mass air flow sensor
throttle body position sensor
engine coolant temp sensor
thermostat(it was stuck and over heating when all this started)
distributor cap and rotor button
fuel filter
also i had the pressure of the pump tested and it was ok
any info and help would be greatly appreciated
fuel pump
fuel filter
thats kinda what i was leaning towards myself, do you have any diagrams showing how to change that??
and IF it were the pump would it run at all when it does not want to start? because when i am trying to start it, i can hear the pump kick on for a couple seconds like its supposed to but it doesnt start, and also when it shuts off on me i can hear the pump then kick off too
NCSurvival
Oct 5, 2012 01:21 PM
leitem
Aug 16, 2012 08:56 PM
jennikz
Feb 15, 2006 12:30 PM
bigredchevyblazer
Suspension Tech
Aug 29, 2005 03:26 PM
