'99 2WD, which Cat Converter?
Hi everyone (that reads this),
Wife has a '99 Blazer with around 180K miles. In diagnosing a P0420, I assume the Cat is bad since all 3 O2 sensors are giving readings from .2XX to .8XX. ODB II tells me there are 3 sensors. Two questions:
Engine runs around 193° in 36° weather 3 days ago. Thanks in advance. Robb |
Catalytic convertor
Looking at the ones on Rockauto, it looks like 3 of the 4 are the direct fit Cat's, and should work. I just replaced mine in my 98 and used the walker model and fit perfect, I also got a $40 rebate, not sure how long that deal is running.
The Eastern model # 50361 is for California emissions vehicles. Not sure of the history of your vehicle, but if you're in TN, and the Blazer was originally from that area, then you should be ok with any of those 3 models. Good luck! |
Originally Posted by Robbabob
(Post 558079)
Not concerned at all with the temp, juts sharing the information that it runs hot enough. in the newer TB forum, cats go bad when the engine is not heating enough.
thanks for the input, guys! |
| All times are GMT -5. The time now is 11:46 PM. |
