99 4.3 slight intermediate skip/miss
my 99 4.3 was running perfect no skipping missing no nothing no cel and on Friday it blew a lower intake manifold gasket, I tore it apart and replace the lower intake manifold gasket put it all back together and it runs perfect again other than a small skip/ miss but it doesn't do it all the time any thoughts on that?
new plugs right after fixing, recent cap,rotor,wires,iac,tps |
My truck was doing this. Look under the hood at night ,check the spark plug wire for arcing. You,ll see a blue spark and may even hear it
If it didn't have it before, it 'most likely' is something you did/touched. Goo back over all you did....hoses tight, not cracked (a carb cleaner may help with this)..all electrical is plugged in properly (ie plug wires seated to cap tightly)..good luck...Jerry
Originally Posted by perumotors1369
(Post 648714)
alright. will check. and i cleaned throttlebody really good whennit was off already.
thanks i will post what i find |
i found a bad spark plug wire havent. replaced it yet. but pretty sure thats causing the problem
Originally Posted by gatrucker99
(Post 648917)
P1345
captain hook. i never have had a p1345 code until i had to change lower manifold gaskets and put the distributor back in how do i fix it
thanks |
2 Attachment(s)
With the ignition off: Using a ratchet and socket on the crankshaft center bolt, manually rotate the crankshaft ONLY clockwise until the timing marks are aligned like this:
Attachment 30823 AND the rotor is within a few degrees of this: Attachment 30824 Remove the distributor and install it so the rotor points to the #6, (or very close) on the distributor housing when the distributor is fully seated against the intake manifold. DO NOT rotate the crankshaft while the distributor is removed. |
i did tdc and rotor is close to pointing to the 6
i would post picture but i cant get it to upload for some reason |
