99 blazer air bag trouble
Does anybody have flash codes for air bag system?
What exactly are you looking for? If you're looking to reflash the computer, GM dealer is the only source. What problems are you having... airbag light on?
Originally Posted by captain hook
(Post 374892)
what exactly are you looking for? If you're looking to reflash the computer, gm dealer is the only source. What problems are you having... Airbag light on?
When the system is powered up the airbag module runs a self test and the light will blink during the test. If an impact sensor, or its circuit fails, the module will attempt a second time to check it. If it fails both times the airbag light will stay on and the system is disabled. The blinks have nothing to do with DTC's. To retrieve DTC's you must use a scan tool capable of accessing the airbag module. The $400 or $500 cheapie code readers that some of the auto parts stores use will not access the airbag module.
| All times are GMT -5. The time now is 06:26 PM. |
