99 blazer fuel problems?
Old Dec 29, 2012 | 05:33 PM
jimblaze22's Avatar
jimblaze22 is on a distinguished road
Default 99 blazer fuel problems?
99 blazer wont cold start unless I use starting fluid. Once it gets warm it will start easily. Did a fuel pressure check on a key on/ ignition off test the pressure will go to 60psi and then slowly go to 0. Idleing it will stay at a constant 55-57psi. As I rev it, it will go to 60psi.As soon as I turn it off it jumps from 55 to 60psi then slowly drops to 0. Dont know if its fuel pump or regulator or something else. Replaced the fuel filter 3 months ago. any help?? Ideas.....
Old Dec 29, 2012 | 05:47 PM
cleburne red's Avatar
One way to tell if it's the pump or regulator is to check the pressure at either the fuel filter, or at the pump itself. This will isolate the pump from the rest of the system. It is supposed to hold pressure after the key is off.
Old Dec 29, 2012 | 06:31 PM
jimblaze22's Avatar
That sounds like a solid idea. How do you check the pressure at those locations. Will my Pressure gauge screw on at those areas.
Old Dec 29, 2012 | 06:46 PM
m0perale's Avatar
m0perale is on a distinguished road
Here's the diagnostic chart/thread on the issue: https://blazerforum.com/forum/tech-a...agnosis-23038/
Old Dec 29, 2012 | 07:13 PM
jimblaze22's Avatar
thanks
95jblaze
Aug 27, 2011 03:46 PM
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
aloppen
Aug 27, 2007 07:46 AM
swatcat
Sep 19, 2006 11:00 AM
