-   -   99 blazer hard starting when warm (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/99-blazer-hard-starting-when-warm-81783/)
cobra49327 09-26-2013 11:15 AM
Hey there my blazer has 157k on it and it starts fine when its not ran overnight or 8hrs after it sits but when you start it after the first time it takes 30 seconds or longer to restart you can turn the key back and forth as many times as you want and it don't help it has a new fuel pump can any one help me?
rexmburns 10-10-2013 10:27 AM
Moved To: 2nd Gen S-series (1995-2005) Tech
WalkGood 10-10-2013 10:47 AM
Need more info, like does the starter engage?, just click?, nothing?? Does the engine turn? Any sputter?
cobra49327 10-11-2013 04:53 AM
The starter rolls fine it starts and dies instantly then it rolls over and over and over for 30 seconds to a minute before it fires up but runs fine after it starts only code is a evap code for small leak
cobra49327 10-11-2013 04:57 AM
I'm leaning towards the fuel pressure regulator or injector spider but not sure. The fuel pump comes on as soon as you turn the key on also
rexmburns 10-11-2013 06:51 AM
Do a fuel pressure/leak down test on it and post your results.
cobra49327 10-13-2013 09:25 AM
Fuel pressure key on motor off 62lbs running 55lbs any ideas not had a tps code iat code and iat is reading pretty high temp it was 76 outside and iat was 135 and there was a p0300 code and o2 sensor codes and if you take the iat out and blow on it for a lil bit the blazer would start easier
burned 10-13-2013 04:30 PM
I am guessing you have a scanner?
Let the vehicle sit overnight and then without starting it check what the IAT and ECT are reading compared to the outside temperature.
